JDMfantasy New Member Dec 1, 2006 #1 Current intake project for the shorter GS bay. Q45 flange will be mounted front and center
KazeSupra New Member Dec 1, 2006 #2 Hurry up and get it on the bench!!! Will I be able to get one that I can mount a different throttle body on?
JDMfantasy New Member Dec 2, 2006 #4 e-solver said: Do you have a casting for the flanges and runners? Click to expand... The lower intake is cut down and sanded to just the bare runners
T toojayzee New Member Dec 3, 2006 #5 JDMfantasy said: Current intake project for the shorter GS bay. Q45 flange will be mounted front and center Click to expand... Yummy... !
S skid Member Dec 4, 2006 #7 Am I missing something or is there a reason the manifold lies flat, should it not be in a 'V'???
cebby New Member Dec 4, 2006 #8 skid said: Am I missing something or is there a reason the manifold lies flat, should it not be in a 'V'??? Click to expand... It's a replacement for the upper only. The stock intakes are two piece. The lower manifold has the "V".
S skid Member Dec 4, 2006 #9 cebby said: It's a replacement for the upper only. The stock intakes are two piece. The lower manifold has the "V". Click to expand... Well I thought that first but then the runner's spacing doesn't look right? The lower half of the original intake more or less has the inlets in pairs, these look equidistant on each side. We are talking for the 1UZ right????
Zuffen Super Moderator Staff member Dec 4, 2006 #11 If you look carefully at the feet of the runners you can see the holes to bolt this down to the head. There are also mounting points for the fuel rails. 2UZ I say. I'd also like to know about bellmouthing like Pro. Attachments V160 (Medium).jpg 87 KB · Views: 60
JDMfantasy New Member Dec 4, 2006 #12 Correct, this is a 2UZ manifold. The top cover section is resting over the floor plate for the photo. The runner have been ported since the pics.
JDMfantasy New Member Dec 5, 2006 #14 Zuffen said: But are they bellmouthed at the top? Click to expand... Yep. I like the quote in your sig. I know the feeling, ha.
G gte New Member Dec 8, 2006 #15 Are you all working on any Dual Q45 t/b manifold's for the 2uz motor? JDMfantasy said: Current intake project for the shorter GS bay. Q45 flange will be mounted front and center Click to expand...
JDMfantasy New Member Dec 8, 2006 #16 2uzgte said: Are you all working on any Dual Q45 t/b manifold's for the 2uz motor? Click to expand... That we are.
T toojayzee New Member Dec 26, 2006 #18 JDMfantasy said: Current intake project for the shorter GS bay. Q45 flange will be mounted front and center Click to expand... Did you get this thing done yet ? Its sick !
