1UZ-HZ
I was a bit scared to post this, but after WEEKS of testing, test fitting AND 2 broken inlet cams, I've found that 2 of my arp studs(one on either side) will not fit in under the inlet cam gear. I've checked everything that would be causing interferance. I used different studs and I had the same problem, to me it is as if the thread that screws into the head is not long enough, I know it doesn't make any sense at all, because Lex has installed these with no problem. ANY comments and suggestions are welcome!!!!
Oh yeh, since this is my "test" engine I replace the 2 studs with standard Toyota bolts, which were checked for stretch.
Thanks for any help
Jeremy
Thanks for any help
Jeremy
