Lextreme cams
Turbo4L
Hey just trying to find out if lextreme stage 2 cams for the 1uz will work with the 33% stiffer valve springs.
Also will they work with a 2JZ bucket conversion?
Has there been any before and after tests with these cams.
Will they also work with the oversized lextreme vlaves, 1.25 and 1.5 mm?
Ben
The std cam is very docile, more lift required..
I guess one of those n/a Kelford cams ??
With the turbine you are running there won't be any issues with reversion / high back pressure...
It seems the RB26 retainers can be used to run better springs ??
Kelford said to me the std buckets are ok up to 80 seat / 180 lift with big base circle cam. The reason they went with BILLET cams...
I guess $1200 isn't too bad for four cams ???
But I'd like to here from leople who have done this? I don't like being a pioneer!!!
Read what is used here?? http://www.lextreme.com/forums/showthread.php?t=6810
