K&N Air filter
Backdraft
Can anyone help with a suitable part number/dimensions for the smallest K&N Cone filter that will handle the job for a standard NA 1UZFE engine?
Regards
Johnno
Bigger is better in you must go with a cone filter setup...
In my opinion the cone filters suck for flow when comparing to the BFI designed intake in conjuction with the 1uz-fe engines.....
My suggestion backdraft is to look into the BFI intake designs, it's free and will flow much better then any K@N cone filter intake...
Just my two cents..
The filter area is too small with the BFI, or stock sized filter.
Go with something that has around twice the area and you'll be fine.
Otherwise you'll be limiting yourself when running over 4,000 rpms.
Then, drill a large hole at the top of the front wheel well, run the intake into that with a filter setup and you will get the best flow....Maybe better then the BFI...
