Intermittent stalling
hrforever
I have a 1996 1UZFE that stalling intermittantly, but mainly when it settles down from initial start-up to a normal idle. I read the forum on this problem and believe the problem is within the vaccum accuator at the front of the inlet manifold, however mine appears different to the earlier versions. There also appears to be water connections as well.
The question is, can it be pulled apart for cleaning or is it a replacement situation.
Yours looks like the later "non-rebuildable" version.
Try and locate an early one as they can be dismantled and reassembled.
The water connection runs to the throttle body to stop icing.
Post up a Wanted To Buy in the appropriate section as quite afew would have been discarded when people went to superchagers.
