How to pull codes with no diagnostic plug??
Kirby
Hey Guys,
Have just put a celsior motor and a crown box in a 92 2wd hilux.
Problem is it won't rev passed 2800rpm in N or park, and in drive its got a massive flat spot, I've tried two other computers and still the problem is there.
i can't hook a scanner up cause the diagnostic plug isn't in my "ready to go" loom.
if i bridge TE1 and E1 on the engine plug to put it in self test mode,wat do i bridge on the computer and wat do i hook my light up to???
Much appreciated Kirby.....
You can do it in the diagnostic box. Check there is 12Volts at the B+ terminal. If there isn't fixing this may fix your problem , very common wiring mistake. Then using a test light run between the W and the B+. The light should flash the codes for the engine. If W is missing from your dianostic box it will be at the ECU - cheers
