HELP with powersteering hose routing
4000GT
Well here is the story. The old powersteering has a cooler and a line to the fluid tank. But I see the 1UZ fluid tank on the pump doesnt have an inlet?
Here is a pic, A used to run through the cooler and go to the fluid tank, B used to go to the pump.
So the question is, can I run B to C and then make an inlet on the fluid tank and run A there and drain through D to the pump?
You have a Soarer or SC400 pump there.
The inlet to the pump is D.
You need to run A to D with a cooler along the way.
The Soarer resevoir is remote mounted and has the return built into it.
You can use a Crown resevoir on the pump and it has a return built in it.
Ok, so B goes to C ok...
And I can mod the fluid tank for a fitting to run A to. The tank I have doesnt have a return sadly but no big deal to mod. Is it best to put the fitting at the top, middle of lower section of the tank?
Thanks mate but I have one, had to buy one motor from Mazline had it missing.
