Gear shifter
truck builder
Vic
Hi guys i have a 1uz-fe from a early 90's crown front cut i have fitted into my Hilux. I want to run an electronic LED gear selector display remote from my auto gear shifter. Is it possible to pick up on wires somewhere to identify which gear i am in?
Use the S1 and S2 wires that go to the gearbox - they are solenoid 1 and solenoid 2. Use Kdogs wiring diagrams (presume you would have these if u've done a conversion already)
They work like this...
1st gear = S1 on S2 off
2nd gear = S1 on and S2 on
3rd gear = S1 off and S2 on
4th gear = S1 off and S2 off
The trans computer sends 12v to the solenoid (the other end is grounded in the trans). Look out for a back EMF spike as the solenoid is an inductive load.
