Hi all, finally getting started on my tt 1uz hg ute project and need some advice on the fuel system setup.
I plan to run a custom alloy tank under the floor of the tray and a gravity feed surge tank. I will be running twin turbo (most likely two kkr330) and also a 100-150hp NOS fogger.
I am aiming for about 450tthp plus 150noshp.
so my questions are:
1. will the gravity feed work well enough assuming the tank is correctly baffled and the feed hose is large enough or will i need a low pressure/high flow feed pump as well?
2. I am planning to use one full time pump (a vl turbo pump?) then use another pump (rated at about 200hp+ and turned on by the arming switch) for the nos. Will this work well enough or is is better to just use one big pump (ie 650hp+) the whole time?
3. Are there any other better options?
I will have heaps more questions over the next few months
thanks
thanks
