I have a 98 GS400 transmission with an upgraded valve body already installed. Transmission runs perfect. Shifts crisply. did I already mention it has an upgraded Valve body installed. No need for your car to be down while getting a valve body upgrade. Or you can remove it and place it in your tranny. 700.00 + shipping. Not really wanting to take the valve body out, but will consider. If I do remove the valve body, I will need your stock valve body.
Also have a 1uz (vvti) post 98 GS4 block. about 90k miles on it. Mechanically sound. Just the block, with pistons/crank, water pump, oil pump. You will need you old oil pan. 500.00+shipping
Also a pre 98 1uz block (non-vvti) for 250.00 +shipping. Whole bottom end with head, no manifolds.
