ECT Power worse then Normal
Memphis3
Hello !
I have strange feeling that my car accelerates on PWR setting worse then on Normal setting. It is possible ? If yes what can I do to fix it ?
Thanks for every ideas :)
LS400 `93
Well I found that the SC400's that run on the stock exhaust systems mostly will start to get gutless after it reaches a certain high rmp.. Like 5000 or so...
The ECT allows the transmission to downshift faster and carry a higher rpm before the next shift occures... From a stand still start I always found the car to be faster with the ECT function off.... Even now with my after market high flow exhaust and headers.... I think maybe a cam upgrade and head work would change that though...
There is no fix, unless you rework your exhaust including headers, get some high performance cams and head work done... Then you may see your ECT function perform better then when turned off....
That's my take on the ECT....
Just some more to throw in the mix... Just launch w/o ECT on and as you start a roll then throw it into ECT once the "off-th-line-lag" is gone. I noticed with a centrifugal supercharger I DONT want ect on either, save me gas as the tach stays lower. I get plenty of low end from the pulley design and all I need is to be able to drop a gear into 2500-3000rpm for get up and go.
