Diagnosis??
Sobe300
G'day, my lux has gone into limp mode (1uz) and won't flash or clear codes. The engine lights stays on solid. Any ideas???
Running very rich, idle at 1500, no change hot or cold, seems to cut spark under increased throttle, no power (like it is under full load similar to a dyno run), flat miss when throttle is punched from idle (no load), seems to run on all cylinders but it's hard to tell. Engine light stays on continuously. Can't find any earth faults, cleaned all conectors, checked relays and fuses. Can any one tell me what wire on the ecu is e1 from the diagnosis plug?? Or if you have an engine wiring diagram that would be very helpful.
