quadcam boat
- Messages
- 360
- Location
- Emerald, Qld Australia
Joel,
here are some photos of how I set up my original cooling system. The water electic water pump is controled by the autronic and only runs when the engine is running. It really only primed the original engine water pump. I made the pipes out of copper pipe I got from a plumber. You can see the bypass tap that goes around thermostat. It was only supposed to be temporary but ended up staying there for 3 years. It is all being changed now as I am removing the thermostat housing and water manifold and am just going straight into the heads.
