Code 13 - RPM Signal?
RedPhoenix
Code 13 - RPM Signal or Knock?
Okay it all started out my car dieing and only running on 4 cyl. replaced the coil pack, everything was good
2 weeks later (as in last week) my CEL/TRAC light comes on. Comes off and on intermitently. I checked codes, got 5 codes all at once, almost like a glitch.
I reset it, all was fine until today, came on again. Check the codes and only thing i got was code 13 (which was 1/5 before hand).
Only thing I have noticed would be a slight jerking here and there while driving. seems after a few of those the CEL will come on. When im idling or the jerking doesnt happen for a few min it will go off.
What should I do?
I found 2 sources, one said rpm one said Knock Control CPU (ECM)
is this the crank position sensor?
