Clutch
rscob
Hey guys can anybody tell me which clutch to use on my 3sgte flywheel with w58 gearbox fitted to a uz,i was thinking of using a toyota4 runner 3.0 v6 cluch and pressure plate or maybe the hilux clutch setup doe's anybody know if this will bolt onto the flywheel,and also is a 13x32x10mm spigot bush ok for the w58:confused:.
Cheers rob
Mr2
Use a clutch for a MR2 turbo. Same input spline as a W58. A 4runner truck clutch will not be pleasing. Can't remember where we got the pilot bearing, probably in a 2JZ kit, it is common.
