clutch pedal in sc300
jtjerry
are clutch pedal and its assy and master clutch cylinter are same in lexus sc300 (manual of course) and in toyota supra mk4?
asking cause I need it for converting my sc from auto to manual
thanks
Jerry
When we changed an SC300 auto tranny to a V160 last year, I believe the owner had sourced pedals from the SC300 manual. He said there was already a place in the driver footwell for the pedals (even though he had an auto). It made sense after he had mentioned it because why would Lexus use two different bodies just for the auto and manual versions.
Eric
Eric
thanks Eric,
I know that lexus sc automatic can be converted "bolt-on" with sc300 stock parts.
question is: can it be done with supra mk4 parts?
clutch master cylinder looks exactly the same, mouting bracket amost too, some differen is pedal: in supra it is aluminium, in sc is steel.
I believe that it can be done with MKIV parts, since the master cylinder should bolt right up, and the slave cyl. will bolt up to side of the V160. As I remember, converting the SC to the V160 was the easier part of that project. : )
Eric
