For the past 11 months, this motor has sat idle but since completing the conversion and now getting the exhaust installed I have a 'miss'. I know the injectoers can sieze, and the plugs can foul (short running time whilst testing), but anything else I should check?
Tomorrow starts with a wheel alignment (new steering rack installed), then checking each injectors operation by listening to them, followed by checking the correct connection of leads from front to plugs, pull the plugs to check rubbish build up and finally the alignment of the stars.
The car starts first turn of the key, idles without labouring, doesn't run hot or to cold, but sounds like a VW Beetle on steroids.
Is there anything else I should look for?
