I am nearly finished acumulating all the bits and pieces that I need to get an M90 on my 1UZ Soarer.
The plan is to run 6psi on stock fuelling and ECU. I have access to a dyno and will be installing an Innovate wideband sensor and gauge for when I do the first power run.
Depending on who you talk to and listen to, a boost referenced fuel pressure regulator is necessary.
I want to have everything available so that when I go to put it together and do a power run I don't want to encounter any problems.
Anyone here have experience that they can share?
Matt.
Matt.
