Parts Adaptronic to SC400 wire loom
kc95sc400
Wired this for my car but have made a new custom loom for my new motor, elimated the ECU plugs all together.
This was wired for my setup on my 95 SC400. This may need some re-wiring depending on you setup of course. It's a bit long but will fit under the stock ECU cover.
The ECU side connector is the same as the SC400 and I think Supras as well that use the 40-40-40 connector.
$100 and I'm pretty firm at this point.
I can also send you an Excel file with a pretty much complete diagram of the harness.
Thanks for looking.
see pic here- http://www.lextreme.com/forums/showthread.php?t=13392
KC
Does this fit a 1996 Toyota Soarer UZZ32 ECU? I know you probably don't know, but worth a shot....
Yes and no.
Yes it should plug into your harness as it is the same 40-40-40 connector but the 96 has sequential injection so you'll need to do some re-wiring on either the engine harness or on this patch harness so you can pair the injectors.
KC
