A341E wiring diagram ??
elliotaw
Can anyone help with a wiring diagram for the A341e transmission? Found a link on the forum but it's not working at the moment.
Elliot
Err yeah, a lot of help from above looking at how many wires are with the new tiptronic controller !
I'm a bit of a dummy when it comes to auto electrics, so need as much help as possible.
On those two connectors, what does each wire do? or do you have a more descriptive version for the connections?
I have 5 plugs on my transmission. Do you have details for the other 3 also ?
Elliot
S1, S2, S3, S4 are the 4 solenoids.
(S3 might be labelled as SLU-)
(S4 might be labelled as SLN-)
B+ = 12v Ignition
That is the 6 pin plug at the rear
P = Park
R = Reverse
N = Neutral
D = Drive
2 = Second
L = Low
B+ = 12v Ignition
NSW are the 2 wires for Neutral safety switch.
That is the plug on the selector stalk.
The 2 pin one at the front of the box is NCO+ and NCO-
If its a Crown box then the 3 wire that bolts to the tranny is SP2
And the other 3 wire that screws in is the speedo.
Need a little help, I have got a Pricol Programmable Speedometer and a 1990 crown motor & trans. I was hoping that you would know what or how these go? Which one of the three wires from the sensor is the output?
