Hello, i took my car in the shop about the a/c and they found two leaks in the same spot in the high and low pressure aluminum hoses right there in the center bracket. They told me to look for a compression fitting kit to repair it, but i'm having no luck. I don't even know where to purchase the entire lines if i have too (which would be expensive, and i'd have to rip nearly the entire engine bay apart). Please help, if you know how to fix this problem. We measured the lines and the large is about 15.85mm(.616in.) and the other about 8mm or (.315in.)
thanks,
will
thanks,
will
