Michael LeCompte
I've pulled some info on the topic from club lexus.
I'm putting a 97 1uzfe into a 95 sc400.
Both engines are sitting side by side on roll around carts and I'm doing a comparision and getting a game plan together on how to handle this.
I'd like to keep the car obd-1. Due to cali smog law. ( I know I can upgrade to a later model engine but don't want the hassles of CARB cert.)
How should I go about this? Swap the whole fuel rails + injectors + wiring harness and use the 95 MAF and ecu?
I have the 97 engine harness + maf sensor + ecu. If you guys think it would be better to go that route.
The EGR routing is different and the coolant routing is slightly different but it doesn't look like much of a problem.
This is a document showing differences...
http://www.clublexus.com/forums/att...-and-95-sc400-engine-differences-1uzfeeng.pdf
Any help would be much appreciated.
