5 speed auto adaptor
duza
I've just decided to go-ahead and fit a VVTi motor into a 2000ish Hilux 4WD. Has anyone been able to adapt the output of the lexus 5 speed auto to fit onto a tranfer case. The earlier 4 speeds are easy to bolt onto a Surf auto transfer, but the output housing of the 5 speed is important for 5th gear and I can see no easy way of having it 4WD without using a divorced tranfer case, which I don't want to do.
I know anything is posssible, but it looks a very involved and expensive exercise to me, unless there is something in the States which can be used.
Ric
i just did that the 4 speed auto from Lexus SC or LS have 23 spline and will fit 23 spline Toyota gear drive transfer cases
Ric
i want to do similar with a 92 surf have 4x4 and use the 5 gears
