I finally took the plunge and bought a 3UZ motor to do a conversion into my Hilux!
This will be a slow process as I am currently working out of my home country. I’ve done a lot of research and preparation. There is a lot more to do and Ill carry on with whatever I can over here.
I stripped all the ancillaries off so far and removed the cam covers and sump.
The one thing I noticed was that one side of the engine (at cylinder # 1) had a lot more gunk deposited inside the cam area. I read on the forum that this is quite normal and nothing to be concerned about.
I will also have to replace the seals in the cam cover around the sparkplug tube. However it looks to me like this cannot be done easily as they are kept in place by the steel baffle that is riveted to the cover. Any advice?
Of course I will also change all the usual suspect items.
