2x MAF
jay-spec
What would happen if two MAF sensors are installed on the same circuit but on the inlets on two different turbos?
The higher voltage would represent both on the single input, unless the ECU code was written for two.
On a 1UZFE with its Karman Vortex, the signal is probably unreadable. Worst case scenario one is on while the other is off. The KV meter creates frequency in a square wave.
actually it depends on which model 1uz you have
if you have one of the later models 96 97 you can run a twin intake no problem but you have to use a piggyback or something to combine the signal
the safc neo will do it no problem at all as it has a twin intake mode
Why waste yr money on that
With twin turbo u need aftermarket ecu
Anyway if u want to do it right
That gets rid of the Maf
Please tell me yr not running orig ecu with
Twin turbo setup
