2uzfe ls430
project d
the whole reason behind the swap i was just saving a buck 430 engine was blown got a 01 tundra re builder i put the 2uz heads on the 3uz and built the engine mounts yesterday and trying to install it tomorrow wish me luck what do you think ill post pick later today
As long as the 3uz has rounded piston domes like the 2uz, it should be a straight swap. If the 3uz has flat piston domes, you will need custom pistons or deal with a low compression ratio afte the pistons are machined to fit.
