C
		cowboy bebop
Guest
2uz cam profiles have a lot to do withi it.  I am taking a set of cams to Crane cams in Daytona to see what profiles they can come up with.
Eric
			The Toyota clutches, almost all, are a push type, where as the clutches for the 1jz/2jz are a pull type. We can convert a 2jz pull type clutch to work with a 1/2/3uz-fe pretty simply.cjsupra90 said:ok guys, kinda off subject, but it was stated that the 2uz came with a manual trany, if so then that should solve flywheel fitment problems. I have not seen anyone say anything about a factory flywheel being availible to make manual swaps easier. If anyone knows anything more about them, please PM with any info that you have.
Eric
