Truck 2002 TRD 4x4
163000 kms (101875 miles)
problem so far oxygen sensor i think left bank something like that OBD2 read
...can racing fuel clean that out after a run?
as of next year ill be looking to rebuild or do a swap
swap will include a 7M engine with a manual transmission, my problem is how do i get the electronic transfer case to work?
if the swap is a no go can i do a Manual transmission swap?
if that's a no go either how much power can the 4spd stock transmission handle?
now for the engine rebuild
pistons and rods is a must
machine the head is a must also
should i go lower pistons and possible look into a STS turbo kit? i think custom will be to expensive
or a little higher compression pistons and S/C? or is stock compression better for S/C?
