1uz Into Lj70 Help!?!
GBI
Hi my name is gary, i am currently trying to build a off road racer. The
chassis front and rear axle + manual gearbox are from a toyota landcruiser LJ70,the year of the vehicle is 1990. I have bought a 1990 Lexus V8 out of a LS400 with most of the wiring loom and ECU ,is this link up possible.
I would like as much information as possible please as this is my first
big project thanks. GBI :scratchchin:
Gary,
Very easy.
Use the searh button. This Site has everything you need to know on it.
GBI,
A couple of pints of scrumpy cider will help. As Rod says all of the info is in here somewhere just have a search. If you can't find the info, be specific in what you are after and I'm sure the answer will be there within a day.
Have fun and post some pics as you go.
Thanks for the link, engine looks sweet.What flywheel, clutch assembly did you use,did you adapt the bellhousing to gearbox plus clutch lever. Sounds like Lex v8 are plentiful in oz over here rare how.
Contact pete at QCA.....he is a member of this forum...qca and he will give you the details as that is who i purchased it from
