does anyone know of a flywheel (for manual gearbox) that will fit this engine? ie off a celica etc...
i can then find one (maybe over here in the uk) and get it drilled for my landrover clutch..
thanks
I had a Rover/1UZ flywheel fitted with the UZ ring gear.
I currently run an 11" clutch on mine but that's bigger than the ring gear.
THe flywheel is scolloped to allow the gear to fit and the starter to engage.
Around $350 from memory.
Its a lightish cromo flywheel made for a Supra clutch.
do you know if this works with the adapter plate that goes from the r154 to auto bell housing?
