Hello,
2 years ago i did a 1uz-fe manual swap in my bmw 323 86" with the following parts
Castle main rod shop:
-10" clutch + pressure plate
-bellhouse
-flywheel
With the w58 supra mk3 transmission.
Engine is running o.k and car is driving well only in first gear whole car is shaking when releasing the clutch pedal.
Problem only accur when the engine is hot, when the engine is cold (higher idle) there is no problem.
Things i already tried
-softer friction material on the clutch plate.
-checked flyweel for axial uncorrections (see pic)
-changed gearbox
Is this a common issue on a manual swap? i cannot find much information on this, i cannot believe nobody had this before.
Hope you guy's can help me out.
p.s sorry for my bad english
-bellhouse
-flywheel
-changed gearbox
