1uz AC Replacement pulley?
Hey lex! thanks for the reply, but I guess I phrased that wrong.
I'm looking at replacing the whole AC unit with dummy pulley, so basically the removal of the whole AC system.
Than that is pretty easy.
You need to release the feon
Unbolt the the two ac lines with a 10mm
Unplug the trigger wire
Unbolt 3 14mm from the side..
yeah, thats good lex, but wouldnt that still leave the OP with a big hole to fill?! ;)
generally speaking, you dont need to fit a dummy pulley, you can just find a way of re-routing a shorter belt and delete it altogeher. theres a few ways to do it depending on on whether you still want to keep the power steer or not. theres some images on this forum and others (!) outlining it all
cheers
ed
