tnt76
- 11
- Portland, Australia
Hi all, I've spent the last week on and off wiring in a Link G4 extreme ecu as a piggyback into my Lexus LX470 (Landcruiser) 4x4.
I'm all done but for tapping in a new ECT sensor in somewhere.
I went piggyback so that I could retain the stability control, traction and trans etc, that the link couldn't control (without setting codes) and std ecu would take care of.
Plan is to build up a good base map that runs the std timing curve (just for a starting point), so currently I have not hooked up injectors or coils.
Connected are:
Crank pos.
Cam pos.
IAT (separate sensor)
MAP (Separate sensor)
TPS
MAF (not needed but thought I'd monitor it)
o2's (both banks, fronts only)
Wideband o2 (permanent install)
Knock sensors
Road Speed
I've been for a few drives while monitoring everything and observing how the factory ecu runs the show.
First thing, which didn't surprise me was how rich it runs at WOT. Well into the 10:1 AFR's and even flickered a 9:1 in there somewhere. I have an OBDII scanner logging also and there is long term fuel trims of around +7 in alot of areas which may also be adding to WOT.
Timing at cruise via the scanner are around 28 - 32 max degrees at light loads, WOT timing in high teens rising to very low 20's through the upper 3500+.
Here's the reason for this post.
Cruise mixtures are always closed loop (no lean cruise) and swing between 100-150mv to 820mv or so as expected from a factory setup, WOT mixtures as mentioned are VERY rich and show on the narrowbands via the LINK ecu at over 900mv both banks (10:1 ish on WB) nothing surprising, just needs tuning. BUT when I back off and it goes into fuel cutoff the WB goes 22:1 +(max lean reading) however the narrowbands get pegged at 1000mv ( I expect to see essentially around 0 -50 mv), totally opposite to expected.
Anyone have any experience with this or also noticed this?
I'm about to do a cold start, as I think I seen a pegged 1000mv when I first fired up after hooking up th NB's yesterday but a hot start. First theory is the heater circuit affecting it????
Connected are:
Crank pos.
Cam pos.
TPS
Knock sensors
Road Speed
