1UZ VVTi cams versus 2UZ non VVti cams
JustenGT8
Canberra, Australia
OK, the story is a little convoluted but stay with me :)
I'll be running a 1UZ VVTi block with VVTi heads BUT i want to run non VVTi cams.
Apparently the 2UZ non VVTi cams fit? A couple of knowledgable sources are confident this is the case but if anyone has actually tried it that would be awesome to know.
What i would like to know is the relative specs of the 1UZ VVTi cams compared to the 2UZ non VVTi cams. I have found bits and pieces of both specs but nothing to compare the 2 directly spec for spec.
I suspect the 2UZ cams are pretty mild and geared more towrads low end torque as per the 1UZ non VVTi cams?
In fact a comparison of specs for all 3 would be useful.
Anyone?
I wish I can fine my 2uzfe cams. I think they are somewhere. I think they will physically fit into the 1uz vvti. You might need to plug up the vvti oil supply.
