mycarhasposessedme
- 419
- Aus, NSW Central Coast
Just putting together my catch can setup at the moment and dug up this old thread searching for what others have done.
I am using 2 catch cans.
The first can will be the main catch tank and is baffled etc and the second can is a compressor air line filter (like Lex is using) being used as a precaution.
Why not just Tee them together and use only one catch can you ask?
Well the problem with joining the 2 cam cover hoses together is that they have different functions.
In order for a closed PCV system to work in a forced induction or na motor you need to have manifold vacuum for low throttle conditions and venturi vacuum for high throttle conditions.
This is the way the system is designed to function from the factory.
Converting a NA PCV setup over to a forced induction setup is not hard and just requires a bit of thought.
If you only have the PCV from the intake manifold, then the only time you maintain negative pressure is under light loads (when you need it the least). Under high boost when the PCV valve is closed, you need to have a vacuum source from the intake tract before the turbo where there is a negative pressure.
The first can will collect most of the oil and sludge and keep oil residue out of the intake manifold.
The second can (compressor filter) keeps oil out of the turbo and intercooler as under high boost the PCV may leak and create positive pressure on the breather hose side which would draw out oil vapors from the valve cover into the turbo.
I don’t think I will catch much with the second can but I will use it anyway as a precaution.
The PCV valve also needs to be moved from the valve cover to the line from the intake manifold to the catch can, to prevent the catch can from becoming pressurized under boost.
Pretty sure what I have described here is what the 2JZ-GTE’s PCV setup utilizes from the factory just with the addition of the catch cans.
Below is my cheesy ms paint drawing of the setup I have described above.
Cheers.
Cheers.
