hilux_bondy_007
hey guys, i csnt get to one of my head bolts and was wondering, wat had to be disconnected off throttle body. i undid the 4 bolts but cant seem get move it forward.
			Its probably just well stuck on, give it a couple of light thumps, or lever a screw driver in there.
It has a large hose that goes to the cam cover, and 2 smaller water jacket hoses, but all of those are flexible and shouldn't stop you from being able to move it.
The hoses on mine are/were.
That's what it will be, the rubber hoses underneath thr TB. Take them off and the TB should just slide off.
Just remove them, they aren't required in Aust.
Just make sure you block them off where they leave the motor.
Perhaps 'very' slightly, but I doubt it would have any noticeable affect.Would it not be heating up the throttle body, and the incoming air?
. .You'll see a small coolant line leave the water bridge at the front of the motor (just behind the thermostat), it goes to the ISCV, then to the throttle body, and then to the water bridge at the back of the motor. Just cap the line where it leaves the front water bridge, remove all the lines, and then cap it where it enters the rear water bridge.
