Just call me "Lex"
- 12,033
- City of Halos
Supercharged 5.4 Liter with 6 speed. What do u think? Best bang for the bucks.
The most powerful factory-built Ford Mustang in history will take to the street next year, following a unique collaboration between performance car legend Carroll Shelby and the Ford Special Vehicle Team (SVT).
Ford took the wraps off the 450-plus horsepower Ford Shelby Cobra GT500 show car at the New Year International Auto Show March 23. Designed in the unmistakable image of Shelby Mustangs of the 1960s, the Shelby Cobra GT500 melds SVT's modern engineering with the big-block performance that made the original GT500 the king of the road.
"The all-new 2005 Ford Mustang is one of the hottest cars in many years," says Phil Martens, Ford group vice president, Product Creation. "Its chassis was engineered from the beginning to be the basis of a high-performance, world-class sports car from SVT, and the Shelby Cobra GT500 is it."
Carroll Shelby lends his support to SVT, adapting his earlier role as a senior advisor on the "Dream Team" that was assembled to develop and build the 2005 Ford GT.
TECHNICAL SPECIFICATIONS
BODY
Construction Unitized welded steel body, aluminum hood
ENGINE
Type V-8
Manufacturing location Romeo, Michigan
Configuration Iron Block and Aluminum Heads
Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
Exhaust manifold Cast iron
Crankshaft Forged steel
Throttle body Dual 55 mm, electronic
Valvetrain DOHC, 4 valves per cylinder
Valve diameter Intake: 37.0 mm
Exhaust: 32.0 mm
Pistons Forged aluminum
Connecting rods Cracked forged steel I-beams
Ignition Coil-on-plug
Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
Displacement 330 cu. in. / 5,409 cc
Horsepower More than 450
Torque 450 lb.-ft
DRIVETRAIN
Layout Rear-wheel drive
TRANSMISSION
Standard (Type) T-56 6-speed manual
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
Final drive 3.31
SUSPENSION
Front Reverse-L independent MacPherson strut, 34-mm tubular stabilizer bar
Rear Three-link solid axle with coil springs, Panhard rod, 24-mm solid stabilizer bar
BRAKES
Type Four wheel power disc
Front Brembo 14-inch vented and cross-drilled disc, four-piston aluminum calipers
Rear Brembo 13-inch vented and cross-drilled disc, two-piston calipers
TIRES AND WHEELS
P255/45R19 tires and 19 x 9.5-in machined aluminum wheels
EXTERIOR
Wheelbase 107.1 in.
Overall length 188 in.
Overall width 73.9 in.
Overall height 55.7 in.
Track width, front/rear 61.9 in. / 62.5 in.
Ground clearance 5.71 in.
INTERIOR
Seating capacity 4 passenger
Headroom
Front row 38.8 in.
Second Row 36.3 in.
Legroom
Front row 42.7 in.
Second row 30.3 in.
Shoulder room
Front row 55.4 in.
Second Row 45.0 in.
Hip room
Front row 53.6 in.
Second row 45.2 in.
Cargo Volume 9.7 cu. ft.
These are preliminary specifications subject to change.
BODY
ENGINE
Type V-8
Exhaust: 32.0 mm
Torque 450 lb.-ft
DRIVETRAIN
TRANSMISSION
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
Final drive 3.31
SUSPENSION
BRAKES
TIRES AND WHEELS
EXTERIOR
Wheelbase 107.1 in.
INTERIOR
Headroom
Front row 38.8 in.
Second Row 36.3 in.
Legroom
Front row 42.7 in.
Second row 30.3 in.
Shoulder room
Front row 55.4 in.
Second Row 45.0 in.
Hip room
Front row 53.6 in.
Second row 45.2 in.
