WANTED: 1st Gen 1UZ rear main seal cover/plate
DaiKaijuProject
So, when changing the rear main seal, I messed up big time and ended up cracking my rear main seal plate and I cannot find it anywhere for the life of me. If anyone would be willing to let one go that would be hugely appreciated because I can't drop the engine back into my SC400 until I get it.
Thats probably an item you'll have trouble finding unless someone is scrapping a block. If its just a crack you should be able to repair it using Devcon. If that doesn't work, then send it to a machine shop who can weld aluminium.
Thats probably an item you'll have trouble finding unless someone is scrapping a block. If its just a crack you should be able to repair it using Devcon. If that doesn't work, then send it to a machine shop who can weld aluminum.
Yeah I'm already having a hard time so that might be the move.
