1999 vvti combination meter speedo
Hi all i am taking the engine and auto gb out of a vvti 1999 ls400. I am also taking the combination meter too. I am making a buggy so would like the combi meter from the donar car so I know all marries up. I am taking the engine management and body ecu across as I see I need the mps communication wiring for the combi meter. I have stripped the car down to what wiring I need so I know it works (hopefully) when I take it all out and move it across
The only thing I can't get working is the speedo. I have the fsm wiring and 4 volume manual from faxon and see that the speedo needs input from the air suspension pps and sat nav ecu. It is a purple and white wire.
Is there any bypass or alternative wiring to get the speedo working?
Hi George. (Sorry to hijack your post Dannyboy).
Re the device mentioned above, do you sell it? Or if not, maybe supply details so I can build one?
Thanks, Jeff
