Ford F-100 3uz/auto transplant
That’s very good going!
Not knowing the Lexus setup in any greater detail, is there a particular reason why you are using the Jag suspension instead of the Lexus?
The jag suspension is proven and is the right dimentions for the F100 , using the front and rear As they are mounted on sub frames that are an easy swap over
Hi Zagamuffin, just curious to see IF your project has progressed over the last few months?
Happy New Year!!!
Happy New Year!!!
same back to you,
progress has been slow but ive managed to buy a lot of parts lol.the list includes
new front and rear brakes discs
front rear pad
all new suspension consumables inc rod ends,bushes and joints ,enough to fully rebuild the Irs/Ifs
full air set up built up,wired and pressure tested
all old f-100 suspension stripped from chassis
new chassis mounted booster/master cylinder fitted
Ls430 eng and box in and out for Ifs locating
new wiring loom built abroad to inc fly by wire throttle,cruise,autobox and immob delete.new fuse block added and redundant cabling removed
still cant locate a Lhd jag xjs or similar
running batt plus and earths
Well, sounds like you at least have a big pile of stuff to throw at it in the New Year!! ;)
What is it that you need a lhd XJS for specifically?
If you're after a LHD Jag box look at US eBay and nearby European Countries.
Google is your friend.
There should be heaps of them available.
2b9nQ1q
Us postage is horendous inc tax tho...
added a few pics in here
https://www.flickr.com/gp/zagamuffin/ToQ8w3
44727051040_8616c79c34_k.jpgIMG_0979 by rob virgo, on Flickr
Hi Zagamuffin,
How is your project coming along, have you had a chance to progress it all since Xmas? :)
