For the roll pin fitting, it depends on the fitting you use. Russel Performance makes two (640281 and 641001). One is 3an on the other end, and the other is 4an.
For the bleeder line, it again depends on the other end of the 10×1.5mm fitting you used.
Where did you buy your fittings?
