well guys countless hours on here, v-eight, and CL but i still have some questions. i have a 93 sc400 i am compliling a single turbo kit for. as a begining step i plan on running an initial 7-8PSI to work the bugs out. i see that the stock fuel system supports 7psi stock and some people use an FMU w/12:1 ratio. ive heard everyone and their mom saying fmu's are a waste of time. i was planning on running the apexi safc but ive been hearing mixed reviews about that also. right now with a goal of 8psi, with a MLS HG, arps, and valve springs i hope to up the psi in the future but thats getting ahead of myself, right now i need to properly control my a/f ratios with my current set up.
set up:holset H1C, 315cc injectors, 255lph walbro, 3" downpipe,my own custom manifolds, apexi FMIC, xs power 46mm wastegate .55 bar spring(7.2ish psi), hks ssq, 4" turbo inlet with AEM dryflow, egr delete, PCV valve on both sides w/catch can, -4an feed, -10an drain, oil cooler w/relocation kit. thats about it for engine stuff, clean up the engine bay a bit-relocated battery to trunk, abs/trac delete,
