ash
Besides .84 t04 housing would flow close to 1.06 T3..
Hmmmm
You sure?
Smaller....![]()
ash pleeeaassse... surely they don't make turbo's any smaller than that
p
single turbo wasn't it, make sure i read that correctly![]()
Hmmmm
You sure?
Larger turbine, small a/r , mid 50 comp
Close... Aha...
it won't be a turbo car then, it will just be like an NA car
say 450hp @ fly, will make that on what 8-12psi. be full boost at 3000-3500rpm even with rear mount?
that cat sleeping on the crank yet?
Good grief!! I leave you boys alone for 5 min and I'm being described as 'old'.I may not be a spring chicken but I still have the need for speed, but maybe not at the 6000-8000rpm levels others like to play at.
All the posts, and my discussion with Ash has given me a greater insight into what I should be chasing, but for starters the "big block" power idea should satisfy. If it doesn't do it for me in the long term, well its only more money, time and fabrication that's needed.
So you should...Lol....." ok"....
What wheels you talking about..
Housing number mean nothing
I've got 150+ hp difference in .81ar to .96 ar on dyno numbers
Lol, that's not close
