regardless, you guys and others like the blue hilux have done a mighty job..
u n ur bloody Pro Mags
as i said before a whole new custom inlet manifold might pick up some power im hoping it does. we just wanted to show that those that can't afford it that there is nothing wrong with the factory unit when it's done right. not everyone is created equal, we have a very switched on fab guy who flow tests everything and knows just what to do. i can't wait till he designs a new manifold, if he could do what he did with a factory manifold imagine when there is no limits
saw millsi's manifold, looked good. we looked at the side entry manifold but worked that front provided the best for us.
there is no competition, but, it's good to have more cars with the UZ engines going fast. they are a good, cheap base engine to start with.
u n ur bloody Pro Mags![]()
Never criticised what you have and i'm record on this forum defending the stock inlet as fine for mostI got by with mine since 2004
Definitely looking forward to what the new built motor will do though![]()
me tooi think things have come a long way since 3 or so years ago when this engine was done. was talking to Joe about the new engine on Saturday, he wants enough power to run mid 7's
going out to WSID on Wednesday to have a little hit, just on 18psi few mates going out also so thought we'd take it for a hit as well.
sound slike you need MFI not efi![]()
Damn, a few mates are heading down and razzing me to have a run now i have the rear end (hopefully) bulletproof...previous commitment though so can't do itSold my MTs as well as needed the cash. Talk about the stars unaligning
Hi my name is aaron and im from new zealnd me and family are builing a alted with a 1uzfe twin turbo with two garrett gt35/82 .80 with some hot cams. Standed manofold but using twin throttle body. Will up load some photo car is still in the build and was wording if any one new were to get a dry sump from for 1uzfe engain.
thanks aaron
Hi my name is Aaron. I'm from new Zealand me and family are building a alted with a 1uzfe twin turbo with two Garrett gt35/82 .80 with some hot cams.
Std manifold using twin throttle body. Will up load some photo's car is still in the build and was wondering if any one knew were to get a dry sump from for 1uzfe engine.
thanks Aaron
we ran the car up at Vince's last night for a quick spot of tuning. we are using E85 Caltex flex-fuel for the street now instead of BP98. it's only a 700rwhp tune, 20psi. took a few degrees of timing out compared to the race E85 fuel. changed from 10 non-resistor plugs to an 8 resistor plug and put the 11mm spark plug leads. engine sounded MUCH MUCH cleaner and crisper![]()
Sounded NICE and clean tonight...
