1uzfe hilux stalling with aircon on!
camshaft
Hi guys. Had my hilux converted a few mths back and just had the aircon hooked up. The problem is that it stalls when the cluch is depressed when coasting to a set of lights and stuff. It idles when warm at around 450-500rpm and when the aircon is turned on it drops below that and stalls. Is there anyway of manually turning up the idle or is controlled by the cpu? Any ideas of what needs to be done to fix it?
Dood, its idling way too low.
Normal warm idle is around 650rpm.
If A/C has been wired correctly it should idle up to around 900 rpm when turned on.
if your in rocky.. pm me ur number..
i will get someone to fix it for you.???
