John..
Thanks, if this really does happen, the real thanks will go to Brad@Fidanza, he could have just blown this off, but decided to take a look at it, and really start to get into it.
That makes sense on the step heights...ill send him the info you send me.
Yea, I knew the diameters between the toyota cluches and temec setups were not gonna be close..the tremecs are 280mm (266mm for mustang)
Unfortunately..I'm one of those tremec guys (t56) but I dont have the skill!
...in the end, that doesnt matter, if we can get this made, Ill figure out something else for my personal setup, either see if someone can make a custom friction disk that uses whatever size they(we) go with (maybe 2500mm 2jz) but has a 26 spline, 1 1/8" input that would accept the t56..who knows..but ill work around whatever we come up with here.
It sounds like that if we need to look at one choice..then I guess the 2jz would be it, as it has the larger diameter. The tremec setups are even larger in diameter, however the spline count would not match. Now, if I could find clutch disks that were 11", but had the 21 spline input, could that work? IE, we drill it for the tremec pressure plates, then guys that are using W5* and R154 buy the disk with 21 spline input? Or the other way around would work to, but the 11" would be the largest diameter of all the options.
As far as for the racing guys, fidanza has that twin plate setup, and the quartermaster unit as you mentioned(didnt even know about that one) so that would probably cover them.
It looks like that if this does happen, its just going to be one part, setup for one clutch/pressure plate. Being there are already racing units out there, and racers have a bit more cash/connections to get these things done, I would think we go with the larger diameter, single disc, street setup as our goal?
I might post a thread at v-eight.com and uzswap.com, just to see what they think also...in the end, I may not even be able to use this because of my tranny choice, so my personal choice doesn't matter. I just want to come up with something that will have the broadest range of applications, which would justify Fidanza making it, and keeping it as a regularly stocked option.
On a side note: I was/am still looking at the Dellows unit, the problem I had with theirs is that its setup for a 10" clutch, that GM never used in the US. However, Ive found that Ford used a 10" clutch on the Bronco 2, so im going to see if I can find a cheap, used 10" Bronco 2 clutch and pressure plate, mail it to Dellows, and they will see if it will work. If so, then we have also found a clutch setup for the Dellows with a non-Australia clutch..that should make it a bit easier for USA guys as well.
(btw..to all the Australian members...I never had a problem with buying from Dellows, or sending my money to Australia to any vendor, and the shipping isn't that bad. My only issue is finding replacement parts (disks, pressure plates) I didn't want to get stuck with having to order from overseas for something like a replacement disk, that I could end up needing one at the track or something. Hope that makes sense..I don't want it to seem like I don't want to spend money in OZ...not the case at all.
ohh, and there's more!...(yea, I cant shutup sometimes)
yup..this would work for the 3UZ as well... my main concern with the 2UZ is that is is a different block, and while ive read that dimensionally they are the same...I wasnt sure. The 3UZ also technically has a different block than 1UZ, but they are for sure dimensionally the same. (in the areas that concern the flywheel that is)
In the end..im pretty sure that this would work for the entire UZ series range...and there is a possibility that toyotas new V8s run the same flywheel mounting flange diameter, and ring gear diameter..if so, then these would work for the new engines as well.
