intake flange plate
XR8tt
Does anyone cut alloy inlet flange plates .. I'm in need of a set to make performance turbo inlet manifold.. For 1UZ...
Is anyone interested in a "group buy" to make some higher flowing manifolds ??
Seems these engines especially in light bodies respond well to better inlet design...
I run a machine shop in Canada, I know, a bit far away. We have a watejet, laser, press brake, cnc mill and lathe, also access to 5 axis machines. If you can't find anyone, send me an email.
Yep. PM me for details...
Well hello Casey; long time.
Real pretty motor in that pic. Wasn't that Chris P's 2UZ that he paid a small fortune for, couldn't get it to fit in his Supra, and then wasn't even able to part it out?
Hey, are you still banned over on SF? Why is that?
Are you & Cowboy still partnering?
Burning questions.....
Now if I had a machine to make these real ...1UZ Hogan manifold..
Note the way the inlet enters through the lower plenum...
These are quite wide compared to push rod inlet where the lower inlet is much closer to each side..
A local inlet made in Aussie..
