Thermactor
Well, I lost an auction by $.50 to get a 3.33" 6-rib pulley for $20.50, so that is out. It might be for the best, though - Arnout's story of a UCF20 spitting out its rods at 7PSI scared the shit out of me. These rods are a disgrace to the Toyota name. The 7M rods can handle 700hp, with two fewer cylinders. Arrgh..
The car: 1996 LS400 with high miles but runs fine otherwise. No oil consumption, fires on all seven cylinders. (we have seven, right?)
The blower: Vortech V2 SC-trim
What I'm looking for: Better midrange response and power. Right now it's downright pathetic.
I have the car, the blower, and the fish bracket. I have a 12:1 FMU in the mail. To start with, I don't want to run an intercooler if I don't have to. I won't do any fuel or timing adjustment outside of installing the Vortech FMU on the return of the fuel rail. Fuel itself will be 93 octane pump gas. Car is a daily driver.
As it is, I'm sort of on the fence between these two pulleys:
http://www.summitracing.com/parts/VOR-2A036-361/ - Vortech 3.60"
http://www.summitracing.com/parts/VOR-2A036-500/ - Vortech 5"
The 3.60" pulley will spin the blower up to 34,100RPM at redline. I believe that in our application, the 3.60" returns 6-8psi of boost.
The 5" pulley will spin the blower up to 24,000RPM at redline. I think that it should equate to, oh, five pounds of boost at redline. Extremely conservative, indeed. The added benefits of the 5" belt would be greatly reduced belt slippage and less parasitic drag on the motor (of course, and less power). One other benefit I can think of is less pressure on me to get a badass bypass valve. I think a Bosch 110 or 114 would probably do me just fine.
I don't want to overhaul or replace the motor. I don't want to spend money on engine management or any tuning at all, at this point. I'm not about to rip out the stock fuel pump. I can do all of those things, but I have no desire to, because they lead one down a slippery slope of modifications and repairs that quickly eclipse 5-figures.
I am just looking at this as a way to get my power up to LS430 levels, and retain stock reliability and economy. My driving style is conservative. In the past I had an MkIII Toyota Supra N/A that I turbocharged, and kept the stock motor. It was a blast even without going into boost or speeding, and I loved the on-highway power surge I'd get with a gentle tip into the throttle. I want something similar for my LS400.
So I'd like your advice. Which pulley do you think would fit my needs better? 2.87"? 3.33"? 3.6"?
.. 5"?
Thanks
.. 5"?
Thanks
