My LS520
My mechanic called me earlier and stated my LS520 is running with a new maf. Idle is little rough due to new oversized valves and stage II cams along with 1.2L extra. This setup most likely need a stand alone or piggyback to operates it. I am also looking for a M112 setup too. So, larger injectors is on the list...
lets find you a reputable tuner and get the adaptronic running. Then the sky is the limit. Glad to hear she's running.
If you're running stock injectors, maybe you should put on some MkIII Supra NA ones for now. If those aren't big enough, MkIII Supra Turbo.
