I recently hooked up my SAFC piggy back ECU and proceeded to tune it rich and then lean and could not gain more then 8whp no matter what I did...I have read reported gains as much as 20whp with Safc only, tuning on several SC's..... I realize when you tune to run lean you get more power but at some point you run the risk of damaging your motor at higher rpms..Also if you have the capabilities to tune the timing as well then HP gains should be made as well....However, I still just don't see how you can pull more then 15whp off of a good tune unless your stock ECU is way out of whack to begin with...Am I right or wrong? Do I need to find a new tuner?
